Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Technical Topics > Turbochargers and Intercoolers
Old 01-26-2007, 01:46 PM
IL KIM IL KIM is offline
IL KIM is on a distinguished road
Default What Turbo
Time to seriously start thinking of which turbo to buy. Was thinking of the PTE 6776 RS (ball bearing). Appears turbo section under Technical Info is getting outdated (which is good for us)
Of course then I would get a torque converter to match. What's the difference between PT 67 and GT 67 and can one buy too much turbo?
Street car, may drag 1 or 2 times. Only want to buy once and grow into it.
IL KIM 85 GN w/86 motor, TRW pistons, Weber 206 billet roller cam, EGR welded, o/sized valves, 130psi springs, roller rockers, 3000 conv, adj w/gate, FPR, custom rad, KB ram air, ported, KB headers, Walbro 340M/hotwire, 60lb Hi Z, CPT66bb
Old 01-26-2007, 02:22 PM
Default Re: What Turbo
Was thinking of the PTE 6776 RS (ball bearing). i think is a great choice..
Old 02-05-2007, 12:53 PM
Engine's getting close to competing rebuild; need to order a turbo.
Anyone compare the TPE 6776R to the CPT 66 ball bearing? What are benefits/minuses for both? What's a P-trim?
Old 02-05-2007, 09:47 PM
[font=Times New Roman]HELLOOOOOOOOO?FONT] Engine's getting close to competing rebuild; need to order a turbo.
Old 02-05-2007, 10:04 PM
The p-trim vs Q-trim is not much of a difference.
p-trim is 2.54" exducer/ 2.92 major
Q-trim is 2.69" exducer/ 3.11 major
Spool time should be pretty similar with the nod of course going to the p-trim since its lighter, but the Q-trim will be a good bit more efficient.
The diameters are not that much different, but the pitch of the blades is MUCH different. You can tell by looking at the blades that the Q would definitely flow more.
For the 231 Buicks, the P trim will out spool the Q trim by a good amount. The Q will probably make up for it on the top end though.
With enough stall, you could spool the Q on the street though.
**info found on T6p
Old 02-05-2007, 10:14 PM
the CPT 66 ball bearing looks to have a T4 flange and wont bolt up to stock style header.. " the mounting flange has 4 bolts"
and i couldnt find anything on a TPE 6776r
did you PTE 6776 ?
Link me to the turbo you are looking at
Old 02-05-2007, 10:35 PM
chrisgarrett chrisgarrett is offline
chrisgarrett is on a distinguished road
I just purchased the CPT66bb and I can tell you it is a 3 bolt.
Old 02-05-2007, 10:37 PM
oops.. i just seen that the T4 is optional
http://www.cottonsperformance.com/products.asp?cat=68
Old 02-06-2007, 12:30 PM
Talking Re: What Turbo
Thanks Phil and Chris. Yes, I meant PTE 6776R. What does the S on the end of your turbo stand for Phil?
So I think I want the P trim for quicker spool-up and mostly street-rodding. It may be work better to offset my bigger headers.
What about the .63 or .82 exhaust housing choice? The effect of the larger .82 moves the rpm power band up a bit? This also affects turbo spool-up? What trade-offs will these housings have mated to the P trim?
Old 02-06-2007, 02:14 PM
Royal-T's Avatar
Royal-T Royal-T is offline
Royal-T is on a distinguished road
S = compressor cover size A/R .70 4" inlet / 2.5" outlet
H = A/R .75 4" inlet / 3" outlet
E = A/R [? .60/.65maybe] 3" inlet / 2" outlet
HTH
