Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Body/Trim/Detailing Tips > Detailing Secrets
Old 06-04-2013, 07:47 AM
pajeff87 pajeff87 is offline
Default Re: Underhood rehabilitation
I haven't touched the intake yet. That will most likely be removed during the winter months and cleaned up. I will probably keep it a natural finish like the valve covers. However, I have used a bunch of Eastwood's restoration paints on our other cars, including the aluminum, silver cad and such. For the most part, I have been pleased with the results and they seem to hold up well. My favorite is their spray gray for a bare cast iron look.
Old 06-04-2013, 11:01 AM
BuickGN's Avatar
BuickGN BuickGN is offline
BuickGN is on a distinguished road
Do you know what, or anybody know, what GM used?
Viktor Zimmerman
87 Grand National
89 TTA
Old 06-04-2013, 09:08 PM
It was probably bare aluminum. Someone else will have to chime in on this one though.
Old 06-04-2013, 11:52 PM
BuickGN's Avatar
The intake is coated, not bare. The valve covers bare. I wanted to know what GM used on the intake. Haven't seen anybody say what it is on all the post searches I did.
Viktor Zimmerman
87 Grand National
89 TTA
Old 06-05-2013, 02:03 AM
Exclamation Re: Underhood rehabilitation
Pretty sure those were painted from the factory.
Old 06-05-2013, 04:52 PM
BuickGN's Avatar
Yes, I know that but what paint or heat coating did they use is what I am trying to find out. I've got answers to everything but what I'm trying to find out.
Viktor Zimmerman
87 Grand National
89 TTA
Old 06-28-2013, 03:57 PM
Shawn N's Avatar
Shawn N Shawn N is offline
Shawn N is on a distinguished road
This is pretty close and Richard Clarks uses it
http://www.kirbanperformance.com/pro...t+%237419.html
Old 06-28-2013, 08:16 PM
BuickGN's Avatar
Thumbs up Re: Underhood rehabilitation
Thanks, just ordered up a can.
Viktor Zimmerman
87 Grand National
89 TTA
Old 07-28-2013, 04:01 PM
The rehabilitation effort moved to the dash today. I had a non-functional tripometer reset, a fuel gauge that reads all over the place, and a jumpy speedometer. I found Casper's instructions for tearing apart the tripometer and fixing it. Wasn't too bad to do and hopefully it will work as it should now.
My biggest issue was removing the cluster from the dash. For whatever reason, I had almost no slack in the tach/boost gauge harness and couldn't access the top right bolt for the speedo assembly. It took some effort to finally get at it as I was being very careful not to break anything. The bolt in the VSS next to the speedometer cable was a bit fun to access as well. I ended up removing the entire I/P surround and used a dab of strip caulk to hold the bolt in the socket to reinstall it.
With the cluster out, I pulled and lubed the speedometer cable. Per Kirban's recommendations, I left the last couple of inches on the top side of the cable alone. Apparently, the lube can work its way up and spray around the cluster making a mess of things. The cable was essentially dry, so hopefully that will calm things down a bit.
I determined what the prongs were on the back of the fuel gauge and then used a spare battery to test it. Connecting the positive and negative prongs it rose to "Full" and grounding the sender it fell to "Empty". I cleaned the prongs with steel wool and the contacts in the gauge cluster with some 400 grit. Clearly, the gauge is functioning properly so if the issue continues it has to be in the sender or wiring.
Old 07-29-2013, 01:33 PM
Very cool ...
On the fuel gauge ... my bet is on the sender/float.
