Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Body/Trim/Detailing Tips > Detailing Secrets
Old 05-19-2013, 09:26 PM
Shawn N's Avatar
Shawn N Shawn N is offline
Shawn N is on a distinguished road
Default Re: Underhood rehabilitation
Check the bushings in the upper and lower control arms
Old 05-20-2013, 07:25 AM
pajeff87 pajeff87 is offline
Visually, the bushings look good. I may just have to pop them off and see what is going on. This is going to be a "driving restoration", so I'll be taking it one vehicle system or component at a time in order to avoid taking the car completely off the road.
Old 05-21-2013, 04:46 PM
Shawn N's Avatar
Might be a good idea for you to get under the rear end and have somebody else rock the rear to see if you can localize the noise before pulling off control arms if the bushings look ok to you. Could just be a shock or a loose bolt on the sway bar.
Old 05-21-2013, 05:39 PM
Lightbulb Re: Underhood rehabilitation
Or even a trunk bumper or seal that could use a bit of lube.
Old 05-21-2013, 05:47 PM
Shawn N's Avatar
It's always something silly for the most part!
Old 05-23-2013, 12:51 PM
ed39 ed39 is offline
ed39 is on a distinguished road
Send a message via AIM to ed39
Thumbs up Re: Underhood rehabilitation
nice looking car... need more go fast parts under the hood tho
blue top injectors, lt1 maf, translator, ATR single shot exhaust, 3inch dp, gnx wheels, turbo tweak chip , atr rear sway bar, super servo, shift kit, stock converter, 210/205 cam at .50 100lb springs, pt 51 turbo street tune for now
Old 05-23-2013, 06:40 PM
Thanks. I have other another car for going fast -- this one will always stay mostly stock.
Old 05-24-2013, 11:32 PM
rmar rmar is offline
rmar is on a distinguished road
Looks great......good save.
Old 06-04-2013, 12:13 AM
BuickGN's Avatar
BuickGN BuickGN is offline
BuickGN is on a distinguished road
Did you do anything with the intake manifold and valve covers? I want to repaint mine to stock color but don't know what to order. Was looking at Eastwood's Aluma blast which they have a video with close-ups. Or their Silver CAD. Anyone know what it is?
Viktor Zimmerman
87 Grand National
89 TTA
Old 06-04-2013, 07:41 AM
The valve covers were pretty grungy:
The covers were hosed down with brake cleaner and then scrubbed in hot soapy water. I then used a brass wire wheel and a very fine wire cup in my die grinders to clean them back up. I elected not to polish the covers, leaving them with a dull gray natural finish:
