Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Technical Topics > Driveability / Troubleshooting
Old 02-12-2019, 01:01 PM
phil errett phil errett is offline
phil errett is on a distinguished road
Default Engine bogs at WOT
My 84 GN is in a shop and the owner is searching for a Snap On red brick so he can pull diagnostics, so I though I would try with you guys again.
I have searched the board and cannot find another reference to engine bogging down at WOT. My engine runs fine as long as I do not go WOT. I can ease up to 80-85 mph nice and smooth, but if I try WOT at any time, the engine bogs and actually seems to slow down. When I ease up on the pedal it goes back to normal.
I have changed the O2 sensor and changed the MAF. Smoke test found one vacuum leak - fixed that - Problem persists.
Has anyone ever had this problem and what did the problem turn out to be?
Old 02-13-2019, 04:43 PM
Question Re: Engine bogs at WOT
Is the car stock?
Does it have the stock chip?
Does it have the catalytic converter?
Old 02-13-2019, 05:33 PM
Ts86ttype's Avatar
Ts86ttype Ts86ttype is offline
Ts86ttype is on a distinguished road
Default Re: Engine bogs at WOT
Is the fuel filter OK??? Maybe partially plugged... Have you put a fuel pressure gauge on and test drove to see if the pressure stays up??? Tom G.
www.tomsttype.com
Grand National Diagnostic Manuals
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
