Old 09-28-2005, 05:03 AM
CKWA CKWA is offline
CKWA is on a distinguished road
Default Need help have a pic included
http://www.360riders.com/leak.jpg
Can someone tell me what they think this is. From a Buick grand national
Old 09-28-2005, 08:43 AM
Default Re: Need help have a pic included
2 more pics i made them kinda large, just looking for some input on if these look pretty bad and are warning signs
Old 09-28-2005, 11:36 AM
Lightbulb Re: Need help have a pic included
My guess is that your rear main seal on the engine is leaking and the oil is blowing back to other regions on the underside of the car.
Look directly under the car, right between the transmission and engine. You may see a great deal of oil leakage coming from this are, and blown out over the torque converter shield, transmission pan, exhaust, and floorboards.
See http://www.gnttype.org/techarea/engine/rearmain.html for repair info.
Old 09-28-2005, 08:55 PM
JHensberry JHensberry is offline
JHensberry is on a distinguished road
i had that prob many years ago, was not the rear main seal, but was a bad leak on the oil sending unit. the oil will leak down from the engine area and "flow" to the back of the car. also, in my case you may want to check the fiberglass rear bumper area beneath the license plate. if it is silty or oily that can confirm a blow back oil leak. my want to try the oil additive with a black light to find the source. Thanks, Joseph.
Old 10-20-2005, 03:08 PM
85T/TYPE/HYPE 85T/TYPE/HYPE is offline
85T/TYPE/HYPE is on a distinguished road
I had a 83 Regal that the heater core went bad in it and it seeped through right in the same spot. Is the fluid oil (brownish) or is it anti-freeze (green)? If it is the heater core it is rather easy to fix (about an hour). Good Luck!
