Low rpm miss😬
Hi everyone New to the group so still learning. I have a 85 Riv T Type with the cold air turbo motor. It has a low rpm miss I can’t find. New Walker MAF ,new plus and wires .Installed new coil ,has old style ignition module with adapter for new style coil .I did notice the material in the module was more of a liquid than a paste .Could this be my problem.? I did put it on a scanner and all readings seemed to be in the ball park .I also ran Seafoam through fuel system to clean it out. Good fuel pressure too. Any suggestions would be greatly appreciated
Re: Low rpm miss😬
Try unplugging the hose to the egr, put a golf T in the hose or something to block it and test driving the car... If I remember the egr would flutter under low rpm and make the engine feel like a slight miss... Give it a try. Tom G.
