Indiana tune up location?
I'm looking for a reputable shop that can tune GNs in the central Indiana (Anderson, Muncie, Indianapolis ) area.
Mr. Keller recommended the following to possibly solve my '87 GN hesitation problem: - Leaks anywhere in the intake (air) tract - between the MAF and throttle body - Weak fuel pump - Clean throttle body - Misadjusted IAC / minimum air setting of the throttle blade - Failing EGR Thanks for any direction you can give me. |
Indiana GN tune up location?
Re: Indiana GN tune up location?
Most of this doesn't warrant much. Someone who is experienced and a TR owner could probably help.
There are TR shops in Hebron (more than just TRs, and principally a turbo vendor, but VERY experienced), and someone who does a lot of TR work and sells parts, but doesn't advertise, in Jeffersonville. There is also a very knowledgeable TR owner that also does transmissions in Mulberry. There are several vendors that also work on these cars in various areas of OH, as well. http://www.precisionturbo.net/ http://www.extremeautomatics.com/ The above links may help. Surprised no one else has replied yet. We have info on how to do much of this on the website, and can talk you through how to do anything that you can't find step-by-step directions for. |
