Where can I get a lock line from? I didn't do an extensive search, so I apologize.
Thanks, Charles
1986 Grand National TE44 42# Injectors Walbro340 Alky Injection 60' 1.79 11.88 @ 113 MPH |
Are you speaking of a line lock? The device used to do burnouts without stressing the rear brakes?
If so, the rebuildable Hurst unit seems to be one of the best choices. That one is a available at almost any speed shop, or online retailer. (Certainly the "large" ones like Summit, Jegs, etc.) If you are asking about something else, let us know.
bump......
1986 Grand National TE44 42# Injectors Walbro340 Alky Injection 60' 1.79 11.88 @ 113 MPH Last edited by MCHdrivesan86GN; 07-20-2009 at 02:00 PM. Reason: bluh |
order a hurst from summit or jegs
This is what I found. Is this correct and everything that is needed?
http://www.jegs.com/i/Hurst/530/174-5000/10002/-1 Thanks, Charles
1986 Grand National TE44 42# Injectors Walbro340 Alky Injection 60' 1.79 11.88 @ 113 MPH Last edited by MCHdrivesan86GN; 07-21-2009 at 08:12 AM. Reason: Ask the question differently |
That's the piece.
![]() You may need a section of brake line to go to the brake booster. Unless you cut, flare, and put fittings on your existing line. Either way there is a *tiny* bit of bending, wiring, and customization to fitting it all up.
Thank you. I'm getting ready to order it and post another thread.
Hope you got the installation kit too.
Not sure what all they might include, other than a short length of brake line, pipe tape, and some plugs for the unused holes in the line lock. And those are things that can be procured though a parts store. Though getting them in one quick package is very nice and simple.
Thanks for the information.
Tags |
lockline |
