Old 01-10-2005, 08:21 PM
psycho6cyl psycho6cyl is offline
psycho6cyl is on a distinguished road
Default choking (coughing) on high rpms
around 45oo and up rpms the motor feels like it starts to sputter or choke out like a little cough any suggestions?
Old 01-11-2005, 07:37 AM
Turbo2nr's Avatar
Turbo2nr Turbo2nr is offline
Turbo2nr is on a distinguished road
Default Re: choking (coughing) on high rpms
Man, this is common, and hard to diagnose. Could be anything, almost. First, start off with a voltage check at WOT, above 3000RPM. Fuel pressure? Then on to ignition system. Ohm coil pack. Was car better at some point oin time? What was the last thing you did to car before these symptoms? Do you have a scan tool?
85 Riviera T-Type/ 87 GN, stock motor, GT67 P-trim .85 housing(no new times yet), 9" non-lockup Art Carr, T-brake, PTE front mount, 3" TB, Power Plate, 7th Shooter, SMC alky, Red Armstrong Chips, ATR rear Sway Bar, 11.1 with old turbo, 1.51 60'
