Old 04-03-2010, 02:59 AM
deus402 deus402 is offline
deus402 is on a distinguished road
Default Re: 85 GN Will not set DTC's but flashes code 12
dunno about the images, they were full size screen shots from alldata, i'll reupload in a better format when i can get back to the shop computer.
do you know what number the ecm is? i have winaldl working now, but it need the number to make it work right... the one listed on the winaldl howto was 1227148, but i'm pretty sure that is for the later cars like you were saying, because the data winaldl is showing using that stream definition doesn't make any sense.
as far as switching over to the newer ecm, i would rather do that as a last resort, but it may have to happen if this one gives me any more problems.
Old 04-03-2010, 03:36 AM
Lightbulb Re: 85 GN Will not set DTC's but flashes code 12
Should be 1226459.
It only fits the 84-85 turbo V6 Buick engine in the Regals and Rivieras.
http://www.exatorq.com/ludis_obd1/c3xref.html#1226459
Old 04-03-2010, 03:37 PM
cool, thanks.
Tags
aldl, dtc, ecm, idle speed, winaldl
