Old 02-28-2007, 03:58 AM
buickpe87 buickpe87 is offline
buickpe87 is on a distinguished road
Default Fuel line O-rings
Hi what is the correct size for the O-rings
- between the fuel rail and return line?
- between the fuel feed line and fuel regulator?
Thanks in forward!
Old 02-28-2007, 05:33 PM
Default Re: Fuel line O-rings
From memory, I believe they are the same ones used for the injectors (cheap and easily available from GM or other sources).
Old 02-28-2007, 07:21 PM
chrisgarrett chrisgarrett is offline
chrisgarrett is on a distinguished road
I'm a little confused about this. The o-ring that connects the fpr to the rail appears to be the same as the injectors, but the smaller o-rings that connect the feed and return to the fuel rail are 3/8". The o-rings at the bottom of the fuel feed and return (down by the frame) are 3/8" feed and 5/16" return.
You can buy the o-rings in a blister pack from napa. The part number is 7304912
http://www.napaonline.com/MasterPage...ng+-+Universal
Old 03-01-2007, 02:45 AM
Thanks! My indication was not so good. I mixed the feed and return. Sorry! Anyway, my question related to the O- ring in the joint between the fuel line and rail(passenger side) and second one in the joint between the fuel line and the bottom of the FPR.
