weird brakes
I have an 87gn with the powermaster system. lately the brakes have started acting weird. the brake pedal is moving slow in the beginning, while depressing it, which results in "brake lag". the relé on the E-H pump is switching off and on constantly. while depressing the pedal the relé starts working even faster. I think the pump relé is bad, or can this have something to do with the accumulator? any thoughts? I'm not a powermaster expert
Re: weird brakes
I believe you were trying to say 'relay'.
Have you checked any of the diagnostic trees? See http://www.gnttype.org/forums/showthread.php?t=9519
Re: weird brakes
Mr. Keller is correct.
You need to run your diagnostics to help determine what your problem is. Most likely culprit is the accumulator. Blown diaphragm. Clicking motors are a sign. Momentary hard pedal is a sign of a dying accumulator. Time that PowerMaster to be sure.
87' Jeep Wrangler - 'Frankenstein' 87' Grand National - 'Zeus' - 200K miles |
Re: weird brakes
thanks. I go to military school, 350 miles from my gn. Not home that often, but I'll run the check the next time I'm home. I noticed the symptoms the last time I drove it. btw; sorry, keller. relay. I'm norwegian
Re: weird brakes
