Powermaster problem
I know it says to check the link for powermaster diagnosis, but any quick thoughts as to what would cause intermittent lose of power brakes, and now when I loose the power brakes the brake light comes on when I step on the brakes and out when letting off. I replaced the pump about two months ago. I am not sure if the accumulator is going and with the cost of it I am about ready to convert to vacuum if I can find a brake pedal from some where then buy the powerbooster and reservior from a parts store. Any thoughts or thoughts on the vacuum conversion?
Re: Powermaster problem
You really need to go through the diagnostic tree. Even the distribution block can light the brake warning light.
Thanks for the advice, I will go through the trouble-shooting list and see if I can pin point the problem part.
When I converted my power master brake system to vacuum, I re-used the power master brake pedal. After you bolt in the new vacuum booster you will see that the pivot point for the connection is in a different spot, I just took the power master pedal and lined it up to the booster, then I marked it where it had to be re-drilled, I drilled a new hole re-installed the pedal and checked it for proper fitting, it's no big deal.
87 GN PTE TA49, adj.fpr. 2 1/2" Pypes ex. 3" ATR downpipe 3" hI- flow cat, Race pro muffs. 60/65lb.mototron injectors, LT1 valve springs, heads pocket ported, 3 angle valve job, 3" LT1 maf/translator, 340 walbro/ hot wired. 93 TT chip,9"K&N. |
I am thinking about attempting that, I was going to purchase a powerbooster with reservior from the a parts store, like NAPA, but I am not sure what vehicle; buick, chevy (camero, monte carlo) or what year to get. Also, where would I get the check valve that is mentioned in the vacuum conversion kits for turbo buicks?
Why not get one for a V8 Regal? Maybe even the inline check valve, too?
Does it matter what year? Also were do I get the inline check valve? Is there a certain part number.
When I went to the parts store I used a master cylinder from a 1987 Monte SS, you can also use that car as a donor for a brake pedal as well if you don't want to re-drill the powermaster pedal.
Use the single or dual diaphragm booster and any idea about where to get the check valve?
You want the dual diaphram booster.
