Valve and timing gear job
I have plans to do the valve spring and timing gear job during winter. So, regarding to it I have some questions about the parts needed. My 87GN (about 110 000 miles driven) is basically stock so the cam is stock as well as valves.
Here the questions for the valve spring job: Are the Comp Cams CCA 980-12 for the springs ok? Can I find the set including retainers, locks and intake seals? If,who is selling? For instance FTP donīt seem to sell the full sets. If to buy separate, what is the part number for the intake valve seals, retainers and locks. Or is it ok to use old retainers and locks and purchase separately springs and intake seals? Here the questions for the Timing gear job: Should I install roller type or stock type set? If stock type,is the standard Rollmaster ok? Branch and part numbers for stock and roller set? Seal(s): what brand/part number? Should I worried about the shimming needs of the roller button debending on the timing cover seal type used or on the other issues? Thanks in advance! |
Re: Valve and timing gear job
Spring you list are fine ...
Lots of part number here: http://www.gnttype.org/numbers/8687pn.html Rockauto.com lists retainers, umbrella seals, etc. for a good price. The sealed power cam/crank/chain is fine for what you're doing ... and it's quieter than the roller.
I believe we decided some time ago that the 979's should be used with the stock 'cups' and the 980's without the stock 'cups' due to their subtle differences in height.
http://www.gnttype.org/forums/showthread.php?t=4461 http://www.gnttype.org/forums/showthread.php?t=8856 http://www.gnttype.org/forums/showthread.php?t=10158
Thanks Ken and Scott!
Further, Which is better solution: to use cups and 979s or no cups and 980īs? How about the seal, is the best solution to use umbrella type ones? Then(again), could I use the old retainers and locks? How about the shimming needs when installing the roller button for the cam? I have heard or read somewhere about the shimming... |
The old retainers and locks should work fine ... inspect them for unusual or excessive wear, but I'd bet they look fine. The stock cam is pretty tame and fairly low lift.
Personally, I'd probably go with the 980s and no cups, just for slightly easier install/assembly. I think it's pretty much a wash which one you use. As far a shimming, I have always had someone weld a small square of thin steel where the button "rides" on the cover. Actually, I think we might have used some JB Weld to affix the plate ... been MANY years ago since we did it). THen use the roller button from a 3800 ... never had a problem. Ken
Ken Mosher 1987 GN original owner 650+ HP Black 2015 BMW 328xi XDrive wagon 2012 Volkswagen Tiguan (the Tig!) Night Blue Met (sold) 2006 Trailblazer SS Red Jewel Tint 395 HP AWD (sold) 2014 Silverado LTZ Crew 4WD 2012 Honda VFR 1200F Tahitian Blue (sold) 2015 BMW S1000R Racing Red 2013 Honda CBR500R Red (wife's bike) 2014 Triumph Bonneville T100 2003 Harley Davidson V Rod Anniversary Edition Last edited by kenmosher; 11-07-2008 at 10:33 AM. |
be sure and put seals on all the valves , intake and exhaust
Thanks again!
How thick or thin should that additional plate for the timing cover and button be? Not any othe "shimming" needs? And how about the valve seals, umbrella type or something else? Part#? (I have heard about some ring type also if I remember right....) |
I just used a very thin piece and ground a little to make it flush to the original surface. Good news is that it's not really critical, so pretty much eyeball it. If you use the roller bearing cam button it shouldn't really ever be a problem.
Umbrella type valve seals ... stock GM ones work fine (and really tough). Make sure you get the ones for the later heads (not the early ones) ... slightly different size. From: http://www.gnttype.org/numbers/8687pn.html original GM number is: 12511890 Rockauto lists both a Sealed Power OEM set (MV1888A pack of 6 for .44 ea) and a Fel Pro set of 6 part no. SS72623. The Sealed Powers look like the stockers. GM Parts Direct still has the OEM kit for $38.
Ken Mosher 1987 GN original owner 650+ HP Black 2015 BMW 328xi XDrive wagon 2012 Volkswagen Tiguan (the Tig!) Night Blue Met (sold) 2006 Trailblazer SS Red Jewel Tint 395 HP AWD (sold) 2014 Silverado LTZ Crew 4WD 2012 Honda VFR 1200F Tahitian Blue (sold) 2015 BMW S1000R Racing Red 2013 Honda CBR500R Red (wife's bike) 2014 Triumph Bonneville T100 2003 Harley Davidson V Rod Anniversary Edition Last edited by kenmosher; 11-11-2008 at 11:03 AM. |
ive had excellent results with the felpro viton and the OEM ones.. I try to use the OEM seals when i can..
Thanks for all!
I start the purchasing project with the information I got from you. |
