Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Add-on Electronics and Electrical > Scan Tools
Old 03-20-2010, 02:37 PM
poppy1440 poppy1440 is offline
poppy1440 is on a distinguished road
Default power logger install question
Hello
I'm installing a powerlogger and plx wideband on an 86 GN with digital dash & 3bar MAP. I just want to double check connections.
#2 on input block spliced into green wire from PAC(alky) measures 1.6v with key on engine off.
#7 on input block is connected to white wire from scan master version 2.2
bung installed in exhaust
power supplied to plx plug
here's my question how do I connect the P.L. to the wide band? I think it's through the 4 pin analog connector supplied with the plx I'm just not sure how to make this connection. And if ya'll see anything else I may have missed any help will be grately appreciated
Thanks
86 gn. 9 inch k&n, walbro 255 hotwired, adjustable wastegate with vacumn controller, stock location stretch intercooler, scan master, 42.5lbs injectors, 3 inch downpipe, tt chip, julios alky, ta 49
Old 04-06-2010, 04:08 PM
aminga's Avatar
aminga aminga is offline
aminga is on a distinguished road
Send a message via MSN to aminga
Default Re: power logger install question
You want to consult the PLX manual and find out which one is the 0-5V analog output. Connect that to the PL input block.
Alan Minga: Lacey's Spring, AL
86 Buick Regal T-Type
