Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Technical Topics > Hot Air Cars - 1984 - 1985 Turbo Regals/ GNs
Old 07-06-2013, 10:02 PM
Red84Ttype Red84Ttype is offline
Red84Ttype is on a distinguished road
Default Oil drain line grommet
I cant find this grommet anywhere and the thing is I dont have the old. Does someone know the part # on that? I know it looks like the pcv grommet, but bigger.
Old 07-06-2013, 10:07 PM
Default Re: Oil drain line grommet
It's no longer available but you can use a PCV grommet if you feel like buying several to see if they'll work.
im referring to the oil drain line connecting to the intake manifold. i need that grommet that sits on top, inside of the manifold. thanks
Old 07-07-2013, 01:04 AM
You mean the one that was used from 1978 to 1985? Same grommet and isn't made any more.
Old 07-08-2013, 09:48 PM
I found the oil drain line grommet. Dormans makes the grommet. Part # 42323 Its a GM pcv valve grommet, but works for the oil drain line perfectly.
Old 07-09-2013, 01:17 AM
Thumbs up Re: Oil drain line grommet
Moved to 84/85 area and stuck the thread!
Old 03-26-2015, 11:40 PM
Buick84TTypes Buick84TTypes is offline
Buick84TTypes is on a distinguished road
The GM part number is 25504235 and GM Parts East shows it as available. It is item 22 in the exploded diagram and parts list at the website below. http://www.gmpartseast.com/buick/com...9mw94gj47.html.
I searched that part number and had various results. Discontinued, available at a relatively low cost of $3.84, and available at a relatively high cost of $31.45. You might still be able to find NOS.
Old 06-12-2015, 07:28 PM
Dusty Fog's Avatar
Dusty Fog Dusty Fog is offline
Dusty Fog is on a distinguished road
This part is still available. Anyone know if the 84 turbo and 79 turbo have the same oil return line diameter? I'm going to need this grommet in a couple of weeks.
Charlie........you out there?
Old 06-12-2015, 09:42 PM
You can use dorman Part # 42323 as a replacement. Shouldn't be that hard to find at a local ports store.
