MAF sensor quit
Where can I purchase the whole conversion to LT1/LS1 +translator option? Any help, Thanks
Re: MAF sensor quit
See http://www.fullthrottlespeed.com/ They have all the components.
Re: MAF sensor quit
Scott, I am new to all of this. Do I only need to buy a LT1 MAF sensor to replace my stock one, or do I also need some type of translator? Thanks
Re: MAF sensor quit
You need the LT1 or LS1 MAF plus a Translator or Translator Plus as a good basic system.
Re: MAF sensor quit
Scott, thanks for the follow up. I guess I don't know the difference in the LT1 MAF and the LS1 MAF sensor, any suggestions? Thanks again!!
Re: MAF sensor quit
LT1 maf 3inch
LS1 maf 3.5 inch |
Re: MAF sensor quit
Thanks for the info on the LT1 and LS1.
Re: MAF sensor quit
Thanks to all who helped me with the info. on converting from my original MAF sensor to the LT1/LS1 + Translator Pro. Hopefully only one more ?, do I have to purchase some different type of wiring sytem for the conversion? Thanks again!!
Re: MAF sensor quit
IF you order it from fullthrottle , they offer everything to make it a total plug in play package. no cuttin or splicing
Re: MAF sensor quit
If you don't want to go through all that expense you might want to check out the discussion about GM actually making the original MAF again under the FAQs discussion about a MAF failing.
I just replaced my failing MAF with a reman dealer one and it works just fine. |
