What is the max inj size that works with a Stock turbo?
The injectors in my engine are 20+years old. They Ohm test ok, but I suspect they are getting tired.
What injector size works well with a stock turbo setup? I might get a slightly bigger cam(less than 206 duration), and I might port the Intake, have gasket matched heads. This is a street driven daily driver kind of car. I do understand I would replace chip on any size bigger than 32's or 36's. Thanks for your advice!
Stan Schackow 84 T-Type 00 WS6 Trans Am 78 SS/KA Trans Am 06 G6 GTP |
Re: What is the max inj size that works with a Stock turbo?
I would go with 30 pounders which I believe are Tomco units. They worked very well when I was running a stock Hot Air. The original injectors are 28 pounders. Good luck- Brad
85GN, Hk exh., 2 1/2 int. DP(no TB elbow) 42.5 inj., adj FP, Walbro 340 hot wired, adj waste, 87 ECM, F-body rad, dual electric fans, 87 IGN HW, TT chip, Alky. Port & MAT heads, TA33C Turbo., powerlogger, WB O2 , 2800 SV., MT DR, 18 lbs boost. |
Thanks what I ran with stock size turbo as well - green stripe Tomco.
IL KIM 85 GN w/86 motor, TRW pistons, Weber 206 billet roller cam, EGR welded, o/sized valves, 130psi springs, roller rockers, 3000 conv, adj w/gate, FPR, custom rad, KB ram air, ported, KB headers, Walbro 340M/hotwire, 60lb Hi Z, CPT66bb |
ive been puttin the motoron 60-65# ers on everything these days from stock 86-87's to slightly modded hot airs.. and with the chips from Turbo Tweak or Bob Bailey they all run great... plenty of room for upgrades and perfect driveablilty
Ok, I should just put in a 30-32-36 to 42.5 based on how high a level I'm going to mod it to. I got a set of 32's in my WS6 ls1 car. Maybe I should use those in the buick and upgrade the Ls1 with the 42.5's.
Will a re-programmed chip help the drive ability of the car at cruise speeds? Who makes best hot-air street chips?
Stan Schackow 84 T-Type 00 WS6 Trans Am 78 SS/KA Trans Am 06 G6 GTP Last edited by kingcrab54; 04-14-2007 at 01:18 AM. |
turbo tweak chips seem to work great on the hot air setups..
