Wat injectors?
looks like i need a set of injectors. was running bosh blue tops was thinkin about goin with those again. but im just wondering wat i should go with. i plan on upgrading turbo and prolbably the intercooler in the future so im just wondering should i up the injectors now or wat.
wats into it so far... cat back exhaust, 3inch dp,hot wire,upgraded intank fp,adj reg,atr ram air intake,turbo tweak chip,rjc racing plate. in the future maybe a ta49 turbo with stock location strench intercooler |
Re: Wat injectors?
Re: Wat injectors?
I think the Bosch "blue tops" would be fine for a street combo with a TA49. They served me well. And, you already have them.
However, there is no doubt that the Mototron 60's are the hot ticket for just about any combination.
Re: Wat injectors?
yea they better be nice for 400 bucks...yea me being 18 and a part time job thats def not in my budget ill stick with the blue tops. worked good before and i wont have to reburn my chip
Re: Wat injectors?
wat about some flowed and matched 50lb'ers??
Re: Wat injectors?
Those will require low impedance drivers to be installed in your ECM.
Re: Wat injectors?
please explain.....
Re: Wat injectors?
the Mototron 60-65# DON NOT need the ecm mod Hands down the mototron 60-65# are the best things out there for the turbo buick.. they work excellent for everything from mild to wild |
Re: Wat injectors?
Stick with the Blue tops for a TA-49 combo. Save that injector money & place it towards an Alky kit where you will see some real gains. You need to run the TA-49 over 20 lbs to see any real gains over a stock turbo & pump gas isn't going to cut it.
Buickless again... for the moment |
Re: Wat injectors?
ok... now tell me why the injectors are rated in pounds wats the purpose for this number. i know the more mods you do i.e bigger turbo. you need to have higher perssure injectors. wat is that pressure is that how much pressure they are relasing fuel at or wat???
