what expected times do you think i will have in 1/4
Just curious on what 1/4 times you guys think i can acheive with the setup i'm installing..
TA-60 Turbo. 3" downpipe TurboTweak Chip Ported Throttle Body and Plenum RJC powerplate 009 fuel injectors Mark Jackson Stock/stretch intercooler with 3" neck & adj. scoop. real art carr 9" non lock up 3000 stall converter 160 degree thermo on 93 octance..? on race gas..? just bored so wanted to know what you all think. |
Re: what expected times do you think i will have in 1/4
how much boost are ya gonna run ??
well not installed yet, planning on 18-20 range
easy mid 11's with the right tune in there..
but why the non lockup converter??? do you really need a non locking converter? |
that was actually already on the car.. pretty much only thing that was already on there i'm keeping
no one else have any idea's?
Tuning and tires are also big factors in how fast you can go. You have a good list of parts, now you have to make them work together by tuning.
2008 rebuild, Comp roller cam, Cat stroker, RJC gridle, CPT66BB, PTE Stock Location, Champion iron, 60# Mototron, ported throttlebody, RJC Power Plate, Jimmy-built trans w/Precision Vigilante converter, ATR SS dual exhaust, Razor alky. |
I think you'd benefit greatly from more than 20 PSI if you have the fuel to handle it.
Don't want to intrude but how much boost can you run on a stock block setup safely?
Assuming you have a knock gauge or scan tool, start at 12 and watch for knock. You should be able to push 14 to 16 pounds on a stock set up.
