Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Add-on Electronics and Electrical > Scan Tools
Old 07-19-2007, 11:18 PM
Fast_t_type's Avatar
Fast_t_type Fast_t_type is offline
Fast_t_type is on a distinguished road
Default Power Logger ?
I have a power logger and I was wondering if there is a way to calibrate it so it reads the proper MPH. I have larger tires on it it is off by a lot. Is this possible or is it in the works.
Paul
Old 07-20-2007, 12:06 AM
Default Re: Power Logger ?
the powerlogger only reads what the pcm sees.. how far off is it reading?? might have the wrong speedo gear in the trans
Old 07-20-2007, 05:25 PM
O well maybe when they update the Power Logger they'll look at this correction. Its off about 5-6mph. My tires are larger than stock so thats life. There 275/65/15 I think. 60 or 65 one of them LOL.
thanks anyways
Paul
Old 07-21-2007, 10:28 AM
mschaffer66 mschaffer66 is offline
mschaffer66 is on a distinguished road
Seems like to me in the set up section of the powerlogger it would be easy enough to add a "what you had" and a "what you have" for gears and tires and let it calculate the offset for the ecm mph reading.
Head over to www.fullthrottletech.com and tell Bob your idea.
Old 08-16-2007, 11:04 PM
Just to keep you up to date. A new ver of soft ware can out for the power logger. It has a speed scale built in so you can correct the speed for different gears or tires. Not as user friendly as DS but its just came out.
