Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Technical Topics > Gauges
Old 08-07-2007, 09:57 AM
MCasteel2112 MCasteel2112 is offline
MCasteel2112 is on a distinguished road
Default Best source for boost gauge?
OK Ive plumbed it into line from solenoid to turbo..or should I say between turbo and Y fitting.
I have now heard best source is in line to my MAP
Thanks
P.S.
And now I know what that damn green wire is for
Its not a Buhog but I found it in field with everything in milkcrates. 10 years, countless hrs and many vacations later
Old 08-07-2007, 10:07 AM
Exclamation Re: Best source for boost gauge?
Actually, that is one location. Any direct manifold location is good. DO NOT use the boost control lines or fuel pressure regulator line.
Gauge can be purchased from any TR vendor (see the vendor page), catalog vendor, or speed shop. I suggest one that can read more than 15 PSI.
Old 08-07-2007, 11:08 AM
Default Re: Best source for boost gauge?
Ive always run autometer gauges although vdo arnt bad
Thanks I'll remove from turbo line and swap to line going to map
mike
